Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Stall Vs 400 torque converter
Old 09-14-2009, 04:43 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
The Th350 & Th400 use the same Torque converter. All Torque converters have a rated stall speed or rpm that they will stall to.
If you have a camshaft with long Duration= degrees of rotation the valve is open you may need a TC with a higher rpm stall rating.
