Stalling on a hill - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2002, 01:12 PM
Post Stalling on a hill
My car stalls and runs rough whenever I'm on any decent incline. I have adjusted the floats on my edelbrock performer. Any other hints as to what it could be?
Old 11-14-2002, 01:20 PM
bullheimer's Avatar
NEVER use credit cards!
Post
adjust them again. howz your fuel pump? is your tank full of gas at the time? up hill as well as down? <img src="confused.gif" border="0">
Old 11-14-2002, 02:14 PM
Post
New fuel pump, yet there is sediment in the tank (50 ford with gm 350) Filters installed pre and post pump, only stalls uphill.........
Old 11-15-2002, 03:10 PM
DJM DJM is offline
New Member
Smile
What makes you think that this is a fuel problem? (No disrespect intended) Does the engine cut out under hard acceleration? Could be an electrical problem, wires, plugs, coil.
Coils are tricky creatures especially if you have only one...(some vehicles have several now) they tend to cut out when they get hot or under load like you describe...old coils that is, or some of the foreign made ones. I have checked several coils and found they check ok when they are cool but will fail test when hot!
