Standalone trans cooler - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2008, 04:24 PM
I have a 27 Model T hotrod Iím building.
Stock 350 motor and 700r4 trans.
Do you think I would OK running a standalone trans cooler and not using the one in the radiator?
http://cgi.ebay.com/ebaymotors/12-DU...spagenameZWDVW
Would I need to run hard lines?
If I do need to use the radiator part of the system could I use this to plumb it?
http://www.speedwaymotors.com/p/6769...ation-Kit.html
Shawn
Santee, SC
Old 03-24-2008, 05:13 PM
I always try to use BOTH ... the extra cooler and the one in the bottom of the radiator. I live just up I-26 from you in the Columbia area and it gets HOT here in the summertime. NAPA and others has a 5/16th tubing with double flared ends that can be bent and used very easily. Shown below on my 700R4.
Simple flaring tools and benders can cost less than the shipping costs on some kits.
Old 03-24-2008, 05:20 PM
Thanks for the quick response Deuce.
I guess I was just being lazy and didnít want to run any more hard lines, just finished my brakes.
Are coming to Santee for the show in April?
http://www.streetrodsunlimited.org/
If so I would love to buy you dinner (LoneStar) and pick your brain for awhile.
Shawn
Santee, SC
Old 03-24-2008, 06:14 PM
life is a temporary assignment
I have ran them cooler on a couple of my car's,It get's very hot here,Like about 105 degrees.I had no problems at all.
Old 03-24-2008, 07:09 PM
NEW INTERIORS,
Did you use the Rad cooler as well or just the Finned cooler?
Shawn
Santee, SC
Old 03-24-2008, 07:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
be very careful of the spin on filter type adapters...... most / many spin filters are directional. Fluid only flows ONE way.
We had a customer come in with his restored 74 Ford 4x4 3/4 ton truck. Big block and C-6 trans. It was a very nice truck.
He had the spin -on filter adapter plumbed in backwards which cut off the flow of the cooler system for the trans.
Old 03-24-2008, 09:02 PM
Originally Posted by monk250
NEW INTERIORS,
Shawn
Santee, SC
All I used was the finned cooler.I had one in my pro street 57 Chevy with a turbo 400,And one in my 32 roadster,with a turbo 350.
Old 03-25-2008, 05:54 AM
Shawn
Santee, SC
Sometimes I go.
I used to live in Charleston many years ago and I know a lot of the guys in Street Rods Unlimited. I like their November event in Ladson better ... It is pre 49 only and has more vehicles than the mall event.
And Crosley is right ... as usual
Be careful if you add a extra filter. The ones I use have IN / OUT marked on them ... so you can not make that mistake on the direction of the flow.
Old 03-25-2008, 06:13 AM
Irelands child's Avatar
This is my second car with this type of cooler - with never a problem on the first. Later this year will be the test for this one but the engine is smaller(302ci vs 355ci) and the cooler is bigger (24" double pass now vs 18" single then) and this one is in a better air flow area under my '31 A roadster's splash shields. I just didn't want more claptrap in my engine compartment - but the rad cooler is there JIC.
Dave W
Irelands child
How big a trans cooler do I need? 1953 Homer Transmission - Rearend 12 01-22-2008 07:57 PM
Trans cooler butch27 Transmission - Rearend 3 09-28-2007 02:35 PM
700rd trans cooler 67chevy Transmission - Rearend 1 06-05-2007 12:57 AM
Trans cooler fittings blacklotus Transmission - Rearend 3 07-04-2005 10:41 AM
Is it safe to skip the radiator and go strait to the trans cooler? Ghetto Jet Transmission - Rearend 20 10-17-2004 09:34 AM
