Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Standard brakes to power brakes
Old 03-24-2013, 09:44 AM
aosborn's Avatar
aosborn aosborn is offline
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
If you have the space under the hood, a 7" or 8" single or dual diaphram booster is very common to utilize. They have 4 mounting studs and you will have to reinforce the inside of the firewall most likely. You can then use an early 80's style Corvette master cylinder. They are available in 1" and 1 1/8" bore diameter's which are the most common. Add an adjustable proportioning valve in the rear line and you are good to go.
The job requires a bit of fab work, but if you have the space it is very do-able.
Regards,
Andy
Search-Master Power Brakes, CPP or talk to your local hot rod shop.
