Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Standard brakes to power brakes
Old 03-24-2013, 10:54 AM
sedanbob's Avatar
sedanbob sedanbob is offline
Since your master cylinder is already on the firewall, it seems like all you'd have to do is re-drill the firewall for the booster, use a 7 or 8 inch dual booster, and replace your master with the same kind with a larger bore -(1" or 1 1/8" as suggested earlier). You will probably have to re-do the lines at the master. Then run a vacuum line to the booster. Should be pretty straight forward.
