Standard brakes to power brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2013, 11:33 AM
vettesplus's Avatar
RedRage
I just moved to the world of streetrods. i picked up a real nice 1934 Pontiac 2dr sedan in a trade. i want to upgrade it to power brakes but not sure where to get the parts. i do not want a frame mounted unit because i have the brakes at the firewall already. just not sure where to start. pic of the new addition to my stable...
Old 03-24-2013, 08:42 AM
RWENUTS's Avatar
If you got room under your dash these guys could help you.
Brake Systems & Parts : Kugel Komponents, Quality Komponents Since 1969
The Following User Says Thank You to RWENUTS For This Useful Post:
NitroMidgets (03-25-2013)
Old 03-24-2013, 10:44 AM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
If you have the space under the hood, a 7" or 8" single or dual diaphram booster is very common to utilize. They have 4 mounting studs and you will have to reinforce the inside of the firewall most likely. You can then use an early 80's style Corvette master cylinder. They are available in 1" and 1 1/8" bore diameter's which are the most common. Add an adjustable proportioning valve in the rear line and you are good to go.
The job requires a bit of fab work, but if you have the space it is very do-able.
Regards,
Andy
Search-Master Power Brakes, CPP or talk to your local hot rod shop.
Old 03-24-2013, 10:54 AM
sedanbob's Avatar
Since your master cylinder is already on the firewall, it seems like all you'd have to do is re-drill the firewall for the booster, use a 7 or 8 inch dual booster, and replace your master with the same kind with a larger bore -(1" or 1 1/8" as suggested earlier). You will probably have to re-do the lines at the master. Then run a vacuum line to the booster. Should be pretty straight forward.
Power Brakes to Munual Brakes Dennis78B Suspension - Brakes - Steering 6 06-06-2012 05:49 AM
s10 standard brakes question chsmith Suspension - Brakes - Steering 5 03-22-2011 09:22 AM
Power Brakes feel like Manual Brakes kbuhagiar Suspension - Brakes - Steering 13 09-10-2010 04:02 PM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 03:07 PM
converting standard brakes to power on a 55 belair Randal4h Suspension - Brakes - Steering 5 09-15-2003 12:45 PM
