Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - standard dish vs d dish
Old 01-10-2013, 05:20 PM
hcompton hcompton is offline
Old & Furious
Originally Posted by 377MONTE View Post
n/a motor.. for now. maybe throw some nitrous at it later down the road. 383 sbc 10:1. dart iron eagle 200s, 64 cc. am i leaving a lot on the table if i opt for the cheaper standard dish?
Is it zero deck cause you can buy flat tops that sit a little further down in the hole.
But yes a reverse dome is best because you can run a good quench area under the pad. But dish can be used. I think flat tops would be the other option not dish. But not sure of your numbers so can really figure it out.
Fyi rebuilder pistons with 64cc heads will come damn close to your goal. But for nos you will want forged.
