Standard fuel pressure regulator question! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2010, 06:19 PM
Hey guys,
The question I have is as follows,
I want to install a standard-1 IN 2 OUT (non bypass style) fuel pressure regulator on my truck but was wondering how it would work being that I have my fuel line and return line coming from my mechanical pump? Is there anyway around it with out buying a return/bypass style regulator?
Old 12-28-2010, 06:53 PM
Cape Cod Bob's Avatar
1 in from the mech. pump
2 out , 1 to each carb or
1 to THE carb and the other plugged or to pressure gauge.
I would suggest at least a temporary pressure gauge so you can set the pressure if it adjustable.
If you are useing carbs be sure to get a regulator thart covers the range for your carb/ pump.
Old 12-28-2010, 07:16 PM
muddi1's Avatar
Hi Chris,
The return line should only be running to the pump from the tank, in the case of the regulator you only have one line coming from the pump to the carb.
Just like Cape Cod Bob said, simply plumb it in line like an after market fuel filter and put a gauge, usually with a 3/8 to 1/8 reducer in the second port of the regulator.
While you are plumbing the regulator in would be a good time to put an after market filter in also.
I used 3/8 steel brake line filled with sand and a Swagelok tube bender that I found on Ebay for $15 to do my lines.
Here are a couple links to sites I used for reference to bend my lines:
http://www.eaa.org/experimenter/arti...ng_bending.pdf
http://www.mustangmonthly.com/howto/.../photo_02.html
http://www.classictrucks.com/tech/07...fuel_line.html
http://www.swagelok.com/downloads/we...N/ms-13-43.pdf
There is also a site that I can not find at the moment that shows how to install a fuel filter like the one I have which is a GM replacement filter that runs about $6 at any parts house.
Name:	fuel lines 006.JPG
ID:	51167   Click image for larger version
Name:	fuel lines 007.JPG
Old 12-28-2010, 07:47 PM
Awesome!
Hey thanks guys!! Makes sense! Really appreciate it!
V8 w/ carburetor + eletric fuel, runs too rich. Do I need a fuel pressure regulator? 5_speed Engine 17 10-25-2009 01:51 PM
S-10 V8 swap Fuel pressure regulator question Andrew7dg General Rodding Tech 5 07-29-2007 08:03 PM
Do I need a fuel pressure regulator? mattson70 Engine 17 07-01-2007 08:03 PM
Fuel pressure setting question for bypass regulator system hotrodf1 Engine 8 05-07-2007 10:26 AM
bg fuel pressure regulator 1931 steve Engine 1 09-15-2005 03:42 PM
