-   -   standard q-jet and ccc q-jet fuel inlets (http://www.hotrodders.com/forum/standard-q-jet-ccc-q-jet-fuel-inlets-232450.html)
gearheadslife 05-02-2013 01:25 PM
anyone know of hand if the threads into the carb inlet are the same or did g.m. change to mertic? with the 80 ccc carbs..
I ask cause all I find in the j/y are the newer ccc ones and my two at home are missing the inlet piece that houses the filter/line
Roger Mabry 05-02-2013 06:38 PM
Here is a link to place that has them all - plus specs
Quadrajet Carburetor Inlet Fittings - Carburetor Parts for Rochester Quadrajet, 4G, 2G, Mercarb & Carter AFB, AVS, Thermo-Quad Carburetors
I have two of them and they work well.
gearheadslife 05-03-2013 08:08 AM
thanks ............
