standard rockers vs. roller tip rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2003, 05:57 AM
Honorary Redneck
Post standard rockers vs. roller tip rockers
standard rockers vs. roller tip rockers;
any real advantage in a mildly tuned street engine?
Old 02-18-2003, 06:19 AM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
A little less friction never hurts (less guide wear at the least).
Old 02-18-2003, 06:38 AM
Post
I installed a set on my 355 I like them, but I'm not sure how much gain you will notice, but like bstmech stated less friction the better. They are fairly inexspensive.
Old 02-18-2003, 01:18 PM
Post
you will notice no performance increase
Old 02-18-2003, 04:36 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Should make your valve guides last longer due to less side pressure. I consider roller tip rockers as a good value for valve train modifications.
Old 02-27-2003, 11:35 AM
Post
Actually, the benefit of the roller tip rockers over the stock rockers is that the ratio will be more consistent and closer to 1.5:1
The stock rockers from the factory can be anywhere from 1.37 to 1.45 so you're not getting consistent full valve lift.
Roller tips can't hurt if you need that last bit of performance, slightly lower oil temperatures at the valves and you have the extra money
Old 02-27-2003, 01:18 PM
aka Duke of URL
Thumbs up
[quote]Actually, the benefit of the roller tip rockers over the stock rockers is that the ratio will be more consistent and closer to 1.5:1<hr></blockquote>
Good Point!
Also, there will be less deflection as they are stamped from thicker metal. Just the lesser side load on the valve stem is worth the price. Less friction...less heat...frees up some power...it all adds up.
I can see where you would not want to go the the expense of full roller rockers, but roller tips just make good sense.
