standard trans to ford big block - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2003, 08:59 PM
Question standard trans to ford big block
Can anyone help me I'm wanting to put a big block Ford into a '32 Ford sedan and make it a stick shift. I don't know what tranny or how to do the clutch linkage? Can anyone help me?
Old 04-12-2003, 04:05 AM
woodz428's Avatar
Troll Hunter
Arrow
I'd stay with a Ford tranny, they are strong and it will be one less piece to fabricate/adapt. There are many ways to hook up the clutch linkage, but the simplest is with a hydraualic clutch system either adapted from a lter vehicle or an after market kit. You might also check some late model 'stang mags and see if someone offers an adapter to a late T-5 and then you could run the cable system.Room is tight but if you think it out as you assemble it you can get it in there.
Old 04-12-2003, 04:16 AM
jalopy45's Avatar
Cool
Not sure whcih BB Ford you want to use, but if it's an FE (332,352,390,427 etc.) look for a bellhousing out of a 60's Mustang, Comet or Fairlane that came with a 390. If you plan on running the engine real hard look at the Lakewood scattershields to protect yourself and they can be had with just about any trans/engine combo. Did a similar swap in the 60's and used a wheelbarrow to replace part of the firewall. Worked real good for clearance but go my butt whooped when my dad wanted to move some dirt.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 04-24-2003, 07:17 PM
Wink
jalopy45,
Actually, I was thinking of a 429/460 size of big block but I would really like to have a 427c.i.. You know the ones that nascar outlawed back in the late 60's early 70's. You wouldn't happen to know where I could find at least a block of one. Let me know please. Thanks,
Jeff
