standard or undersize rod/main bearing??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2012, 04:09 PM
I'm re-ringing a sbc400. To keep it short and simple, I'm running a high volume oil pump. So do I go with standard size, or .001??? It's the 1st time the engines has been taken apart. No wear.
Old 06-15-2012, 04:28 PM
BOBCRMAN@aol.com's Avatar
Throw away the H-V pump.. Then have the crank checked and order appropriate bearings.
Many people think the crank shows "no wear". When in reality it is way off. Not round and/or tapered in the crankpins. This is the backbone of the engine. No place to guess. unless you have deep pockets and like to rebuild from mistakes..
Old 06-15-2012, 04:38 PM
Run a stardard volume pump, HV pumps will rob you of about 10 HP per say, HV are used when running bigger bearing clearences larger than spec.. As mention, have the crank mic for trueness and size, undercutting the mains and rod journals not always a bad thing as it reduces bearing speed, heat and friction, 10-20 under not a big deal, just make sure you get the correct oversize bearings when you have the crank refinished as I hope you would
Old 06-15-2012, 04:52 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 on what Bob said, do it right the first time.
Cole
Old 06-15-2012, 05:28 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Cole
Where have you been Cole, it's been lonely here without you.
Old 06-16-2012, 08:13 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
oil pump
HV oil pumps are for 4 wheel drives with low idle speeeds. On a high rpm engine you will suck the sump dry. You can polish a crank. You don't have to turn it unless you've spun a bearing. I just mike the crank and use plastigage for extra insurance.
Main & Rod Bearing Clearance to oil weight dbilski Engine 9 05-18-2011 08:55 PM
Cadillac rod & main bearing clearances 327NUT Engine 5 04-05-2011 01:22 AM
What rod/main bearing sizes on a 90' 305? ace_012 Engine 3 05-27-2010 12:04 PM
Rod and Main bearing ? 6426yy Engine 8 03-25-2006 07:26 PM
GM main & rod bearing clearances Sagacious Hotrodding Basics 1 10-09-2004 12:38 PM
