Standard Vacuum Line Sizes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2013, 10:54 AM
andrewakessler's Avatar
My project truck is an hour away, but i'm trying to purchase some silicone vacuum lines to install. Are there standard line sizes (3/8, 3/16) or is it all dependent upon the carb, etc used in the build.
Also, should I be purchasing a vacuum line 1/32 smaller than the fitting to ensure a snug fit?
Thanks,
-A
Old 10-14-2013, 11:06 AM
techinspector1's Avatar
Wiki Edits: 326
When I needed vacuum lines, I would measure the nipples with my 6" dial caliper and buy that size line. Never bought anything for anything that wasn't measured and thought-out first.
The Following User Says Thank You to techinspector1 For This Useful Post:
andrewakessler (10-14-2013)
Old 10-14-2013, 12:37 PM
But that would require doing it the right way....
I was hoping there was a standard, but you are correct that measuring is the best way to go.
Old 10-14-2013, 02:24 PM
From what I have seen so far for really old style stuff such as hooking up stuff to a carburetor there is a 1/8 inch 1/4 inch and 3/8 inch size rubber hoses that you get at your auto part store but there other sizes too but those are the basic sizes to star off with. For example I use a 1/8 inch hose for my vacuum advance and and a 1/4 inch for my transmission vacuum modulator and 3/8 for pcv and brake booster.
The Following User Says Thank You to eric32 For This Useful Post:
200R4 line fitting sizes... S10xGN Transmission - Rearend 4 02-19-2009 06:14 AM
where is best for vacuum line? sabino56 Engine 29 12-02-2006 04:58 PM
Quick ? brake line sizes. Bluepen Suspension - Brakes - Steering 3 02-10-2005 04:30 PM
Brake line sizes for a id10t! 52Caddy Suspension - Brakes - Steering 3 07-01-2004 06:36 PM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 03:25 PM
