Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - standard vs high volume oil pump in 555 bbc
Old 06-22-2012, 05:31 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is online now
It depends on how the engine was set up on build. Loose bearing clearance and other maxed out specs. will require HV pump.
I try to avoid them. If not done properly. They can cause cam wear problems on flat tappet engines. Both at the front thrust surface and the pump drive.
