Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - standard vs high volume oil pump in 555 bbc
Old 06-22-2012, 05:54 PM
lmsport lmsport is offline
You can modify a BBC pump to dump the pressure relief back to the pan rather than cavitate it in the pump body. Then the load on everything is the same until the oil system needs the extra volume.
