standard vs high volume oil pump in 555 bbc
I am wondering if I should run a std or high volume pump in my full roller dart 555 bbc. Its a street/strip motor. Ive heard std would be fine but high volume is a better choice.
If you have wide bearing clearances a HV would help maintain pressure, otherwise I would go with a standard pump, JMO. I've heard pros and cons about a HV sucking sumps pretty bad, consider a deep pan.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
You can modify a BBC pump to dump the pressure relief back to the pan rather than cavitate it in the pump body. Then the load on everything is the same until the oil system needs the extra volume.
SBC's and BBC's have excellent oiling systems. A standard pump with a GOOD filter, such as a NAPA Gold, and quality synthetic oil, should get you all of the oil pressure you need. That old saying of 10lbs of pressure for every 1000rpm holds true. Anything over that and you are sucking extra hp to drive the pump. I had an old sbc with a high volume pump and on a cold start it would shoot up to well over what the gauge would read, lol. Gauge went to 80 iirc. At a hot idle at 850rpm it would have 40lbs. I thought it was awesome, lol. Little did I know I was losing power.
| 454 high volume or standard oil pump | ekacpuc | Engine | 7 | 07-08-2010 04:59 PM |
| Do I have a high volume or high pressure oil pump ? | y2k600f4 | Engine | 6 | 12-16-2008 07:12 PM |
| High Volume or Standard Oil Pump?? SBC | 89SDime | Engine | 6 | 07-09-2007 08:58 PM |
| which oil pump for a 406? high volume or high pressure? | 406 ss monte | Engine | 23 | 09-10-2006 07:48 PM |
| High Volume Oil Pump | 1948Butch | Engine | 8 | 02-10-2005 01:25 AM |
