start problem with electronic igntn-help
Switched over from points to a crane electronic ignition, may be coincidental, but ever since --- after the initial start(which seems to work fine) it drags, or seems to stall while I'm cranking it. I thought the battery was low- recharged--didnt make much of a diff- thought had too much advance- but only had 10 degrees initially - backed to stock of 7 degs (have a rebuilt,bored,cammed 390) still the same issue. if it sits a few days (and possibly builds a charge) on the first crank- its fires after a few revolutions. The next start- it doesnt matter if i drive it 6 feet , or 10 miles-------it will turn over- pause-turn-pause-turn,turn, pause- then fire. like the starter is bad? but all first starts are fine. Is the electronic igntn drawing more power than the battery/starter have to give? I think im hooked to a full 12volt start source. any advice?????? This is a 69 ford galaxie convertible- if that helps anyone. I really appreciate any thoughts on this
Things to check
1 battery, have it load tested 2 battery terrminals, take them apart and clean them 3 Distriburtor advance, could be sticking and taking a while to release. 4 Starter 5 Engine ground and starter positive conection if you think ignition is causing it (over advanced) then yank the coil wire and try to turn it, see if the issue goes away. bateries genearally dont "build back up" by themselves. Usualy what happens after sitting a while is the starter cools down anddraws less to crank. |
Actually a battery CAN build a charge if left alone, but I don't think that is the problem here, I'd say you're running on the battery, so do a load test on the alternator, It sounds like it's not putting out enough amps/volts to recharge the battery... |
Battery
Doc here,
A battery will build a surface charge just sitting from low to to high, HOWEVER, this charge will only last a few seconds under a slow drain, and die right away after a high drain.... To check your advance condition.. Pull the battery wire from the coil and crank.. if it cranks normally, you have timing issues..Pull and plug the vacuum advance line to be sure it isn't holding the advance plate full advance..If you have a spark delay (one way vacuum valve) in that line pull it and run direct. If it continues to "Bog" with the coil dead, you most likely have a bad solenoid. Doc
Aftermarket Solutions Electronic & Electrical Innovations Last edited by docvette; 09-18-2005 at 06:30 PM. |
ill give it all a try---------but, the solenoid is new, the battery is new (when i say "new" it new since the rebuild - maybe 3-4 months and 200 miles) , my voltmeter shows 14 volts when running. Im not running the car long enough - most of the time- to cause a hot starter problem, but maybe thats the issue, im not allowing the battery to charge fully as im really just moving it in an out of the garage, etc----but, it didnt seem to have that problem with points installed.
although the battery then was much "fresher". It just seems too coincidental that it seemed to happen immediately after I installed the electronic ignition. I double checked my timing at that point thinking I had too much advance---but it showed 7degs w/o the vacuum adv. Ill check my battery, advance arm in the dist., and go from there. Thanks for the advice so far--keep it coming!
| Need help with a stubborn 4.3L V6 that won't start | Mad Maggot | Engine | 14 | 10-06-2011 11:48 PM |
| Cranks/No Start Problem | RCastle | Engine | 13 | 12-22-2004 04:51 AM |
| new motor wont start...problem??? | IWasBlown | Engine | 12 | 06-21-2004 09:20 AM |
| hot start problem | tnsmith10 | Engine | 1 | 09-05-2003 06:03 PM |
| Warm start problem SBC/Firebird | Kaylah | Electrical | 4 | 03-30-2003 01:45 PM |
