-   -   Start up problem (http://www.hotrodders.com/forum/start-up-problem-37961.html)
Dreadlord 04-18-2004 04:28 PM
Start up problem
When i try to crank my engine over it wont fire it sits there and and cranks but doesnt show the slightest sign of combustion. What could be going wrong here thanks.
crazy larry 04-18-2004 05:48 PM
what type ignition? need way more info. does it have gas?:mwink:
Ghetto Jet 04-18-2004 05:53 PM
Shoot some starting fluid down the carb (if it has one) and see if it wants to start.
Dreadlord 04-18-2004 06:06 PM
its a 3.1 V6 fuel injected and i tried som starter fluid didnt work and it has gas.
crazy larry 04-18-2004 07:14 PM
does it have fuel pressure? (schrader valve on the fuel rail)
when you turn the key on, can you hear the fuel pump humm?
Dreadlord 04-18-2004 07:51 PM
yea you can hear the fuel pump humm but i havent checked the pressure
poncho62 04-18-2004 07:54 PM
Check for spark...................................bet you don't have any.
crazy larry 04-18-2004 07:59 PM
DITTO.
