started my project car (warning, import car stuff inside) - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2007, 09:43 PM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
i put some air in the tires
started gutting the drive line
threw all this **** on the ground
have the new engine sitting in the driveway
luckily the tranny will be easier to pull off ... cause its got a lightening hole ... or is it speed hole?
screw independant rear suspensions !
Old 06-15-2007, 09:44 PM
Wiki Edits: 22
hope my turbo is big enough
subframe is off, tomorrow ill liberate the transmission from the block
wiring harness was removed and put away till later, that will need a load of mods'
edit: and oh yea, looks like my custom bellhousing might also have an integrated midplate for mounting the engine. might have to build the front section of my roll cage early so i can mount the engine thru the fireall to that
Old 06-17-2007, 09:33 PM
What kind of an engine is that you are puttin' in there? Looks like a fun project.
Old 06-18-2007, 01:39 AM
Is that a taurus SHO engine? thats all I can identify.
Old 06-18-2007, 02:06 AM
Wiki Edits: 22
3.0 sho engine w/ 60k miles
well the old engine and tranny are laying in the driveway
next stop is a quicky dangle of the v6 in the engine bay so i can mark the firewall for clearancing, and check some fitment stuff
then ill gut the front suspension,replace the framerails,do a temp reinstall of the suspension and see whats next
and i think the HVAC unit is going where the rear seat is, so i can still have heat / ac but be able to notch the firewall for the heads, which hang off the back of the engine pretty far. otherwise the front edge of the pulleys on the 3.0 will wind up the same place they were on the old motor .... and thats just to far forward for my tastes
Old 06-18-2007, 11:33 AM
Wow thats a pretty off the wall swap then. I'm all for doing swaps good luck with your build
Old 06-19-2007, 07:44 PM
Wiki Edits: 22
yea, its a pretty od swap but it should be a fun car
2600lb's and a 220hp engine that can rev to 8500 with no probs (besides needing bigger cams
Old 06-21-2007, 08:00 PM
Wiki Edits: 22
how much the heads hang off the back of the block, ihave to notch the firewall that much and more, because the water outlet willbe in the backnow, and i needroomfor that too
pack of cigs is against thee tranny bolt surface, and a pack of cigs is about 3.5" .... notice the bolt boss hangs out even further then the pack does
FRAME RUST !!! sawzall's fix everything
the second pic shows the lower section of the rail, which is almost as bad as it is under the booster
theres a decent sized holeunder the gas pedal also, but its an easy fix, only otherreal rust on the car is the pass side door in the middle of the panel. texas cars for the win. leaky maaster cylinders and screw on door gaurds for the loss
one more of the frame, showing the floor hole better
Old 06-21-2007, 11:41 PM
Why are you ditching the 240's Independent rear suspension? If I'm not mistaken the factory differential can hold a very respectable amount of power and you wouldn't have to worry as much with twisting off the line. I know there are Smallblock Chevy guys running around with the factory diff.
Old 06-22-2007, 08:42 PM
Wiki Edits: 22
this is far froman optimal rear end for the car, all the bushings are shot, everything is rusted, its the open diff, the weak axles, the struts are on the way out, and i would have to buy the control arm upgrades to get proper adjustability
by the time i got done upgrading the rear suspension all i would have left of the old stuff would be the crossmember, the knuckles and the springs
id much rather just throw in the FREE 8.8" ford rear end i have, which just got new 373 gears, anda full bearing kit, and the quadshock setup, and shocks,like 500 miles or so ago .... definanlt less then 1000 miles ago
then all i have to do is pull a set of 5 bolt axles at the junkyard, swap in racing wheel studs, and fabup my own caliper brackets for w/e size rotor is large enough and cheap enough
and then all i need are REGULAR coil overs and a stack of heim joints
ive already got all the tubing for the control arms (free)
ive already got precut tabs for the frame side pivots (free)
ive already got a load of frame material (free)
ive already got a bunch of plate for making brackets out of (guess the price,lol)
this rear suspension is so cheap id be stupid not to use it
Old 06-22-2007, 11:19 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
How much boost are planning to run? This is a very interesting swap. An sr20 would be easier but everyone has those now.
Old 06-23-2007, 11:29 AM
Wiki Edits: 22
boost is a trivial number for the most part
ill be looking at EGT's and RWHP ... ill just keep bumping the boost / water injection till i cant get anymore power out off the enine
Old 07-20-2007, 05:48 PM
Wiki Edits: 22
some gutted interior parts, dash bar is laying on the other side of the car (will be replacing that with a roll cage bar)
the bare firewall, including the removal of the factory sound deadening, which was just laying in there, no longer attached like it should have been
close up of the drivers side. i will need to remove the brake pedal / steering column mount by drilling out the spot welds, relocate the master cylinder to the left, modify the gas pedal, then modify the bracket to hold the modified brake pedal, install the cage, notch the bracket, and then reweld it around the cage bar (fun)
see the pedal cable coming thru the firewall ? see the center line of the master cylinder .. now look at the top of the firewall, that marker line (juuust above the brake lines) is the edge of my cylinder head :bloated:
and here's the inside view of the same section, notice how much of the pedal / column bracket is in the way
when i get the carpet out ill lay out my firewall / tunnel / floor cuts using some fine line white tape to show what I'm planning before i make my cuts ... pics when i get to that ...
how would you make it legal?? spooki General Rodding Tech 8 08-31-2003 09:16 AM
Story time. Halloweenking Hotrodders' Lounge 17 05-19-2003 10:16 PM
Too much exhaust noise inside car jpd37 Engine 5 04-10-2003 03:41 AM
