Started new project 46 chev PU need help with suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2007, 10:13 PM
Countilaw's Avatar
Cox Custom Cars
I've started a new project with a 46 Chevrolet 3/4 ton pickup. It currently has 8 bolt split rims. I want to change the axles to 6 bolt rims like on the 1/2 ton pickup. Any ideas?
Old 04-29-2007, 11:56 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
I don't know if you can swap out the 3/4 ton axles for 1/2 ton axles as those rear ends are different. I am not even sure if you could weld up the holes in your 8 bolt axles and redrill them for 6 bolts. The simple way would be to swap rear ends including the springs and mounts.
Here are a couple of links that may give you some help:
http://chevy.tocmp.com/chevyresto/4670.htm
http://chevy.tocmp.com/chevyresto/46index.htm
Maybe someone else can jump in here.
Old 04-30-2007, 02:50 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
One is to change out the axles with half ton bolt pattern..the other is to get the new style rims for tubeless tires..that is the easier way..changing out split rims for modern tubeless tires has been done a lot on older trucks..and the wheels for that are readily available..
Sam
Body - Exterior "Tips of the Day" Jon Body - Exterior 11 09-07-2007 11:29 AM
57 ford pu project hotrod66_57 Hotrodding Basics 27 12-20-2006 09:27 AM
My project - Suspension (Continued) gbowne1 Hotrodders' Lounge 24 08-17-2006 01:01 PM
Started my Hemi/Willys Project Journal! steve392 Engine 1 05-11-2006 10:06 AM
37 chevy pu project daniel peeples Suspension - Brakes - Steering 6 11-28-2005 03:17 AM
