Started wiring 1951 chevy car, need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2005, 08:38 PM
New Member
Ok I have the new EZ wiring harness ran to the back for tail lights etc. I put in some two wire bulb sockets that ground on tail light assembly. The tail light assemblies holes are to big and it looks like I will need to use the old ones? The olds are spring loaded when pushing the bulb in them? Can I find these new at the local auto parts store? I wish I could explain it better to everyone. The harness is pretty cool and I am taking my time making sure everything is triple checked and wires are covered with a loom etc. Hopefull when I am done this will give me convidence to go onto bigger and better things. Any help on the 1951 stock tailght buckets would be helpful. Maybe they make after market ones that you can buy from a chevy parts place.
Thanks in advance
Old 06-23-2005, 02:18 AM
docvette's Avatar
Wiki Edits: 12
Lights
Doc here,
Here is what I would do if I was you....
Take the original Tail lamp Assembly's with you to the Auto-parts store...match up the Compression rings, type of bulb to be used ... AND Highly Suggest you get the type with a separate ground wire added..
Doc
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 08:57 AM
58 Chevy Apache : Brake Lights / Wiring Harness Rathimis Electrical 3 12-13-2005 08:34 AM
Started the car after winter break zeeman19 Engine 1 05-16-2004 01:20 PM
how would you make it legal?? spooki General Rodding Tech 8 08-31-2003 09:16 AM
