It Started!! Yay!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2008, 05:47 PM
It Started!! Yay!!
Hey guys, so I finally got to turning over the key yesterday on my first SBC build. I started the 383 stroker about 2 and a half years ago and yesterday I finally decided to see what would happen. Well it started up almost instantly and sounds AMAZING. I am now adjusting the carb and timing to allow it to idle smooth. For some reason it will die if I bring the ignition timing anywhere below 35 degrees advanced. It is at about 40 degrees advanced right now and seems to idle the smoothest there (no vaccuum advance hooked up yet). Isn't this WAYYYYYYY too much advance?? What should I be setting my idle timing at?? It is so weird because I can't even get below around 35 degrees advanced while it is idling or it will die on me. lease help with any thoughts and/or opinions.
Thanks,
Keith
Old 06-19-2008, 05:53 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Be honest... Did it bring tears to your eyes when it fired up?
Are you sure you are where you think you are as far as timing? I mean what are you going by? Tape? New damper? Pointer?
If it is really way to much advance you will have trouble starting the beast. You may even break a few starter noses off. I know this all to well.
Old 06-19-2008, 06:30 PM
Thanks,
Keith
Sounds like the distributor is off a cylinder.
Bogie
Old 06-19-2008, 06:44 PM
techinspector1's Avatar
Wiki Edits: 326
Move all the plug wires one hole clockwise at the distributor cap and report back.
Old 06-19-2008, 06:52 PM
Jmark's Avatar
There are two available balancers and two available timing tabs. If you have the wrong balancer/tab combo, you will be way off using a light, even though you can make it idle fine.
Just Getting Started! jrf69roadrunner Introduce Yourself 1 11-14-2005 06:07 PM
getting started in autodody cruzindablvd Body - Exterior 15 10-18-2005 07:51 AM
Just getting started Rat-rod Introduce Yourself 2 08-07-2005 11:21 AM
Started my Journal Fat_46 Hotrodding Basics 1 07-28-2005 11:09 AM
Where to get started. 35Ford Body - Exterior 4 02-25-2003 12:56 PM
