Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter
Thread: Starter
Old 02-11-2013, 03:35 AM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
It's prob a bad starter, it could be improperly shimmed but if that were the case you should get some movement. I'd pull it and get it tested, the old jumper cable while on the ground trick doesn't put a load on the motor so I wouldn't trust that method, beat myself up for a week doing that trick....... ended up taking it in and sure enough it was a bad starter
