Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - starter
Thread: starter
Old 09-15-2002, 05:24 AM
dklong's Avatar
dklong dklong is offline
Post
try retarding the timing , to much base timing will cause an engine to roll over slow and hard, check batt cables for good connections and grounds, if everything is ok ,test your batt if ok, then remove the starter and take it to a rebuild shop and have it load tested.
