starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2011, 01:49 PM
starter
I have a 1992 chevy P/U with a 350 when i try and start it it just clicks one time then nothing cant seem to figure this out battery is fully charged
Old 09-30-2011, 04:08 PM
EOD Guy's Avatar
Cables good?
Old 09-30-2011, 05:20 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 check the cables and the connection could be a loose connection.
Cole
Old 09-30-2011, 06:08 PM
T-bucket23's Avatar
Wiki Edits: 26
Turn the headlights on when you try to start it. If they go out you most likely have a bad connection on the battery cables somewhere. If they stay on the starter is probably no good. Keep in mind this is a very basic test. You may have a stuck brush in the starter. You can try giving it a whack with a hammer to see if it works.
Chet
Old 09-30-2011, 08:28 PM
starter
checked cables hit starter several times with a hammer still one click only and nothin it just started this a day ago and the first time i pulled on the cables to starter and it worked but not now
Old 09-30-2011, 09:10 PM
bentwings's Avatar
bentwings
Might as well try a solenoid. I just did one for about $12.
Old 10-01-2011, 04:02 AM
EOD Guy's Avatar
X2 solenoid
Old 10-01-2011, 09:14 AM
Frisco's Avatar
Glad To Be Here
Below is a list in order of 'most likely reasons' for your problem.
First thing to check is:
Remove cables from battery terminals. Clean battery terminals and the inside of the cable ends. Re-attach.
Look for a carbon like residue inside the cable ends. There may be similar deposits on the battery posts. This will act as an insulator and must be removed. It can be scraped out/off with a pocket knife if you don't have the wire brush type battery post/cable cleaner.
Also check that the ground cable is clean and securely attached to the engine block.
Second item to check:
Starter solenoid.
Next item to check:
Starter motor.
Final item to check:
Ignition switch and the wiring and connections coming from the switch to the starter solenoid.
Old 10-01-2011, 03:33 PM
EOD Guy's Avatar
If you have access to the starter sol...... I sometimes use an insulated screwdriver and short the large battery terminal on the starter to the small sol post (the one that the wire from the ing switch hooks to), the starter should engage...... if it does it's your wiring between the sol and the ing switch
Old 10-01-2011, 07:46 PM
Cape Cod Bob's Avatar
clickity cliclity clicity means weak battery. One click means bad contacts on solinoid or bad starter. The solinoid pulls in but the current don't go thru the contacts or if it goes thrun the contacts it can't getb to the starter windings.
Starter help. Can you make a new starter old? Hogger Engine 2 09-21-2010 10:48 PM
changed from oem starter to high tork mini starter , wires .? don wills Electrical 2 09-04-2010 05:34 PM
starter grinding update Powermaster starter question RossR90 Engine 2 08-11-2008 02:46 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
starter migz Electrical 1 09-03-2007 02:53 PM
