starter??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2003, 09:08 AM
needhelpincali's Avatar
starter???
Hopefully someone out there will know what I should do... Just last week I had a new starter and a new flywheel installed in my '62 karmann ghia... unfortunately it still sounds horrible when I start it, and it still takes like 5-6 tries for the engine to turn over... any thoughts????
Old 08-18-2003, 09:12 AM
What sounds horrible?? The engine or the cranking?? If its a " scream" coming from the starter and flywheel connection, try no shims, then 1 shim , then 2 and so on.
Old 08-18-2003, 09:14 AM
hmmm
Okay... I know nothing about cars!! ha ha... what's a "shim"??
Old 08-18-2003, 09:18 AM
Ill try to explain it. Shims are like little spacers that go between the starter and mounting bolt holes. They're like 1/16 of an inch in thickness.
Old 08-18-2003, 09:21 AM
I'll have to bring that up when I take it back to the mechanic this week! Thanks for the tip!
