Starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2013, 06:09 PM
Starter
How do you check to see if your starter silinoid is bad? On a 85 chevy 350
Old 02-10-2013, 06:20 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
click
Connect a jumper from the battery + post to the S terminal on the solenoid.
If you get a loud click (thunk) noise and the starter cranks (whawhawha) the solenoid is OK.
If not there are several other that could be wrong.
vicrod
Old 02-10-2013, 06:47 PM
EOD Guy's Avatar
Here's how I'd do it.
Use a volt meter and make sure you are getting 12v at the starter (large cable from the battery) If no 12v.... clean or replace battery cable.
If you are getting 12v at the starter..... make sure it's in park and use a screw driver and jump across the large pos stud on the starter and the smaller one marked "S" you should hear a metallic click and the starter should turn the engine over, If no click or spin ...... remove the starter and take it to a auto parts store for testing.
If it spins, but doesn't turn the engine over..... it's probably the bendix/solenoid
Old 02-10-2013, 10:36 PM
I tried starting it with the screw driver and it was making electrical pops an sparks.. No movement tho.. I replaced it and that didn't fix it
Old 02-11-2013, 03:35 AM
EOD Guy's Avatar
It's prob a bad starter, it could be improperly shimmed but if that were the case you should get some movement. I'd pull it and get it tested, the old jumper cable while on the ground trick doesn't put a load on the motor so I wouldn't trust that method, beat myself up for a week doing that trick....... ended up taking it in and sure enough it was a bad starter
starter
Starter help. Can you make a new starter old? Hogger Engine 2 09-21-2010 10:48 PM
changed from oem starter to high tork mini starter , wires .? don wills Electrical 2 09-04-2010 05:34 PM
starter grinding update Powermaster starter question RossR90 Engine 2 08-11-2008 02:46 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
starter??? needhelpincali Engine 4 08-18-2003 09:21 AM
