Starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2005, 08:38 PM
juiced66malibu's Avatar
Starter
My 71 truck starter went out. I went underneath the truck and there were only two wire hooked up. I think there should be three: Hot wire (battery); green wire (ignition) and black wire for ground. Am I right.
Old 09-19-2005, 08:58 PM
docvette's Avatar
Wiki Edits: 12
wires
Doc here,
No..
Main battery cable, to main solenoid bolt..and (usually) a 10 gauge wire fuse link to the fuse buss and alternator..
The "Start" wire to the "s" Terminal on the far left.
The Secondary Ignition (if so used) to the "R" or "I" terminal on the far right.
Ground is achieved through the mechanical mounting of the starter and / or mount bracket on the rear (some have it , some don't)
You should be able to test start it by jumping the "s" terminal to the main bolt terminal with a remote start button (or , and I DIDN"T say this..a screwdriver..) and it should crank.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Chevy 350 cracked starter mounting hole w pics skiprec Engine 14 11-11-2011 06:47 AM
Starter keeps starting and battery exploded Huug Electrical 13 10-06-2005 05:48 PM
Starter questions zipfactor Engine 6 08-07-2005 07:10 AM
Starter woes Again dollybud Electrical 11 09-01-2004 04:16 PM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 05:48 PM
