Starter 99 Tahoe
I have a 99 Tahoe and put in a new starter but it won't shut off when I turn it over. Turns motor good but will not shut off until Batt is unhooked. Does the ignition have anything to do with disengaging the starter. Ig is not hooked up yet????
The ignition will need to be hooked up so the car starts. That is a squirrelly system that I still dont understand.I guess it Is a kind of shunt system, where as the starter will stay engaged untill the engine starts, at wich time the current demand of the starter drops so does the current running through it, allowing the shunt circuit to drop out.I have noticed on these that you can turn the key to start and immediatley let the key back to run and the starter will crank untill the engine starts.Not sure if shunt is what you call it, it is one of GMs better Ideas...
| Third row tahoe seats in a rat rod | Studedean | Interior | 1 | 06-13-2011 11:22 AM |
| Wiring Diagram for Command Start CS-396i Remote Starter for a 1996 Chevorlet Tahoe | Chevy_Rick09 | Electrical | 1 | 08-13-2009 02:59 PM |
| Starter shifting and grinding.. new starter? Where does starter brace go? | 84Z | Engine | 8 | 11-12-2007 02:44 PM |
| 04 Tahoe is way to smart | 302 Z28 | Electrical | 29 | 09-14-2006 05:07 PM |
| 98 Tahoe to 68 Truck | Earl E. Model | Suspension - Brakes - Steering | 5 | 02-06-2005 10:00 AM |
