starter bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2010, 08:29 PM
starter bolts
hi i bought a mini starter (staggered) for my SBC thats in my s10. after like 3 or 4 starts the bolt come loose just enuff so it doesnt make contact with the flex plate. the holes arent stripped out i can tighten them ( dont have a torque wench ) with the 1/2 drive, so they are tight.but dont want to snap them off. ill get a torque wench this weekend but what should these be torqued at so they dont come loose . these bolts came with the starter
Old 06-14-2010, 08:34 PM
bolts
the best thing i have ever done to abolt that wouldn't stay tight is loc-tite
Old 06-15-2010, 02:55 AM
i was thinking that last night also maybe a lock washer
Old 06-15-2010, 04:02 AM
if theyre good bolts they shouldnt break off, are they real starter bolts with knurled ends on them or some cheap chinese knock off?
i tighten mine till im read in the face lol
Old 06-15-2010, 08:31 AM
If it is a gm style mini it takes special bolts 10mm shank 3/8 thread bolt.They were designed for 10 mm mount bolt which gm switched to when they went all metric on us.A standard starter bolts shank is slightly to small allowing the starter to wiggle around causing this problem.
Old 06-16-2010, 03:13 AM
well the bolts came with the starter and they are knurled just where the tread ends guess ill take a spin to a dealer for some or salvage yard thanks guys for your input
Old 06-16-2010, 05:46 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
No matter what you do include the proper torque of the bolts as part of the fix ....
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 02:41 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
