Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - starter clicks once then loses all power.
Old 01-29-2013, 04:05 AM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Have no idea if it's right or not, cause I don't know where those wires end up, sounds right tho'. On the small black wire with the small opening...... use a test light and see if you are getting 12v when you turn the key to start and 0 volts when the key is in run...... if it is that is the wire that goes to the "S" terminal on the starter.
You basicly need a ground, 12v to the large lug, 12v to the "S" terminal, for the starter to spin.
