Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - starter clicks once then loses all power.
Old 01-29-2013, 08:17 AM
Kapn.K Kapn.K is offline
Verify your wiring to the solenoid as mentioned earlier. I had this exact symptom. Click then everything when dead(dash lights, etc.). Shut the key off and then I could make it do the same thing. Battery cables. Normally just clean the posts and clamps. If that doesn't do it, check the other end of the cable. Black/negative should be on the block and you already know where the red/positive is(big red one on the solenoid). In my case, one of the cables had a replacement terminal that bolted onto/sandwiched the cable, that's where my problem was. I can't remember if I replaced it or just cleaned it. Good luck.
