Starter cranks key off ! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2005, 10:45 AM
anthonyc's Avatar
I just installed a MSD 6a box in my Monte Carlo along with a Mallory Uni lite dist. When I went to reconnect the battery the starter began to crank with the key off . I followed the wiring diagrams from MSD and Mallory very well. and cant figure this out . The car was origianally equipped with a HEI . If any one can help I would really appreciate it thanks .
Old 04-03-2005, 11:36 AM
poncho62's Avatar
Wiki Edits: 5
Wiring problem.....
Sounds like your power to the starter solenoid, was also connected to the coil, so that you would have power while cranking. I guess the MSD has power to this all the time. I can't see how that is correct. Recheck your diagram.
Old 04-03-2005, 12:02 PM
malc's Avatar
Living At The Speed Of Life
Is this the wiring diagram you used, maybe someone can see where you went wrong ?
Old 04-03-2005, 01:11 PM
anthonyc's Avatar
Yup thats the diagram I used . Thank you for the replys, I am gonna go take a look right right now . I dont think I wired it with the starter solenoid and the coil connected that way but anything is possible. I will let you know what happens.
Old 04-03-2005, 01:30 PM
anthonyc's Avatar
I'm sorry I should have explained better. The starter runs but is not engaging the bendix gear . I connected the heavy red wire to the big terminal on the starter, could that have something to do with it ? The coil and solenoid are wired properly. Thanks again.
Old 04-03-2005, 01:50 PM
poncho62's Avatar
Wiki Edits: 5
OK...Thats different...sounds like the solenoid is shorting inside directly to the other big post below the one that you have your battery wire bolted to. Or, part of your wire connector is touching it.
Old 04-03-2005, 02:01 PM
docvette's Avatar
Wiki Edits: 12
Solenoid
Doc here,
Disconnect the battery, with an ohm meter measure between the big red wire on the solenoid, and the terminal that goes into the starter..If you get a reading, replace the solenoid...Its shorted...
Why it picked this time to do it is anybody's guess..but sounds like coincidence , since nothing you did would cause this.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 04-03-2005, 04:24 PM
anthonyc's Avatar
Thanks for your help fellas, the wires going to the solenoid were touching this heat sheild wire loom I have on there which was also touching the small terminal on the solenoid and making it short. I straightened it out and the car car started right up. Unfortunately it started raining so I couldn't drive it . But thanks for all your help.
starter & ignition stay engaged with key off 67cuda Hotrodders' Lounge 7 09-06-2004 10:20 AM
starter & ignition stay engaged with key off 67cuda Electrical 0 09-06-2004 09:31 AM
SBC Starter Keeps Cranking W/ Key Off 71chevss Electrical 11 11-11-2003 12:49 PM
Starter keeps running with key off? asennad General Rodding Tech 9 09-15-2003 07:48 PM
Chevy starter cranks and cranks, cranks Walker Engine 5 07-22-2003 12:33 PM
