starter cranks over when i hook the battery cable up - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2012, 02:47 PM
My starter turns over when I hook up the battery terminal. I have switched the wires around and it still does it. I replaced the wiring going down to the starter, so its all new. The starter is new also. I went as far as changing the steering column. This is on a 1978 z28 camaro.. any help will be appreciated.
Thanks
Old 10-06-2012, 03:01 PM
F-BIRD'88's Avatar
Yada Yada Yada
There is a short between the battery terminal and the "S" terminal on the solenoid.
it is either the solenoid itself or or the wireing between the solenoid and the ignition switch or the ignition switch.
A ohm meter will find the short.
Old 10-06-2012, 03:06 PM
thank you very much
Old 10-07-2012, 12:22 PM
s terminal should only have 12v when the key is in start
if you tried a different starter likely its in the wiring like f
bird said
Old 10-07-2012, 01:05 PM
T-bucket23's Avatar
Wiki Edits: 26
I have seen solenoids with out the spot for the tab to hold the positive cable in the right position or a positive cable without the tab cause this. When you install the positive cable it can lay over into the s terminal. Most likely this is your issue if the solenoid is not broken.
Chet
How to hook up kickdown cable. binkwink@telus.net Hotrodding Basics 2 03-06-2012 04:26 PM
How to hook up a 700r4 TV cable Linez35 Transmission - Rearend 7 10-21-2010 09:29 PM
Speedometer cable hook-up latebloomer Transmission - Rearend 2 06-02-2010 09:29 AM
Starter cranks key off ! anthonyc Electrical 7 04-03-2005 04:24 PM
Chevy starter cranks and cranks, cranks Walker Engine 5 07-22-2003 12:33 PM
