starter draggin 77 350 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2010, 08:42 AM
i have a 77 chevy 350 bored 30 over fresh build and i am havin problems with the starter i got 6 shims on it and its still draggin
Old 03-10-2010, 10:39 AM
DoubleVision's Avatar
First off, are the correct bolts being used? if so, remove all the shims, clean the bolts. Inspect the starter, in the holes the bolts go through you`ll notice 2 grooves made into the starter the shoulder of the bolt falls into. Clean the grooves. Bolt starter back on, torque the bolts to 35 ft lbs. Make sure there are no washers on the bolts.
Next, what do the grounds look like? If you have a simple ground from battery to alternator bracket this won`t cut it. Run a ground from the block to the battery and another from block to frame. Next, check the spark timing. Check the mechanical advance in the distributor and make sure it`s not sticking open.
Another Chevy Starter Issue (pic) Bluecollarron Engine 15 10-07-2013 11:12 PM
Mini starter on 350 chevy and bolting on. eric32 Engine 3 03-05-2010 07:17 PM
84' 350 SBC Starter Problems Gokussj5okazu Engine 8 05-14-2007 05:16 PM
Buick 350 or Chevy 350 72Skylark Engine 21 02-02-2006 02:10 PM
Will this work? Chevy 305 Throttle Body w/ Chevy 350 aberg12012 Engine 9 05-07-2004 12:28 AM
