Starter drive gear jammed. (won't retract) - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2013, 09:33 AM
Hello all, hoping for some help. Fairly limited knowledge here. I have a sbc engine with starter problem. The car can sometimes start once and run fine, but then when attempt to start second time starter gear gets stuck in flexplate. I crawl under and push starter gear back to place. Bought a new starter - it jammed. Tried shimming - no luck. Had original starter rebuilt since I knew it lined up perfectly and had worked many times before recent problem. Bench test is fine... but on the car same problem. Started once, then jammed. A friend suggests it is electrical but I am confused. I thought it would be a mechanical issue since it is a spring that disengages/returns the starter drive gear? I don't think flexplate is bent or damaged. Any suggestions? Thank you very much.
Old 05-09-2013, 11:12 AM
delawarebill's Avatar
starter
it ain't electrical !!!!! have u pulled it and did a bench test several times ??? if u didn't have a problem before u got it rebuilt then i would not think its the flywheel.. gotta be in the starter somewhere... pull it..
Old 05-09-2013, 11:25 AM
Thanks
Thanks for the quick reply Delawarebill. I did bench test and the starter seemed fine. Just seems too coincidental that original starter had the problem and when I had it 'rebuilt', the auto electric mechanic that did it said it seemed fine but he spun 'something' in solenoid to improve contacts. Same problem of jamming after that. Also, a new starter I tried had exact same issue. Bench tested all and all seem fine. Not sure what to check next. Friend with more experience than me thinks voltage/electrical issue. Is it possible that electrical could be 'weak' and engage the starter with flexplate, but then not have enough power to spin it? Just causing it to jam? Thanks again.
Old 05-09-2013, 04:13 PM
EOD Guy's Avatar
The electrical pwr shouldn't have anything to do with it not retracting, once you release the key and pwr is disconnected, the spring retracts the bendix.
Loose connections or corroded cables would prevent the bendix and gear from engageing fully, which my jam the gear into the flywheel etc.......Here's a long shot...... pull the spark plugs and see if the starter hangs
Old 05-09-2013, 04:23 PM
Thanks EOD guy, I'll give anything a shot.
Old 05-09-2013, 07:53 PM
Banned
i have had this problem. try a new positive battery cable!!
Old 05-16-2013, 09:33 AM
Here is an update on what I found. Just one more thing to add to my future diagnostics list. Since I put back the original starter and the gear got stuck in the flexplate again, logic said the geometry had not changed so shimming would not help. It turns out the voltage regulator was faulty. The battery was not being properly charged but apparently had just enough 'juice' to engage the starter but not crank it over. It's a very good, high amp battery, so maybe if I had a worse battery it would not even have engaged the starter. Anyway, thanks for the suggestions and that is what I found.
Take care.
Old 05-16-2013, 03:33 PM
EOD Guy's Avatar
One of the best things you can do is convert it to an internal regulated alt, I did mine and all my elec issues went away.
starter gear won't move 0pyders General Rodding Tech 28 11-29-2010 03:46 PM
No reverse gear and slippage in Drive 2nd gear. jadejoky28 Transmission - Rearend 14 04-09-2009 11:49 AM
One headlight won't retract 81 Corvette Dejavu Electrical 8 10-15-2007 11:51 PM
Starter won't start and fuel pump won't pump after engine reinstall Porschev Electrical 26 02-16-2007 04:43 PM
Swapping Gear Drive Out for Timing Chain or Belt Drive - Need Suggestions horvath Engine 4 05-24-2003 08:47 PM
