Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - starter/electrical problem
Old 07-19-2006, 01:05 PM
meev182 meev182 is offline
i have a dvom now...
no, its not an automatic going where a manual is, so no nuetral safety or anything. i think the problem is with the ignition switch wiring. the previous owner had a pa system in it and i took it out... the connector had 3 wires, one which was going to the ignition spot on the fuse box. is the wire coming from the fuse box supposed to go to the ignition switch?
