starter fitting problems
I have a 76 nova and i just recently had to swap the original 250 w/ integrated intake to a 1970 250 i already looked up the casting numbers and it said it was cast in december of 1970 and i bought a new 168 tooth flywheel and a starter to bolt up on the '70 250 but it wont bolt up because the flywheel is hitting the nose cone and the pinion on the starter any ideas?
i have a 153 tooth here and ive tried it already when i put it up the nosecone hits the flywheel and ive checked the part numbers on the starter and its for a 70 model 250 and the flywheel as well
the flywheel is already installed
i cant even get it close enough to bolt it on with the 153 or the 168 is there supposed to some sort of spacer block or something like that? |
i figured out the problem i had the wrong flywheel size i had a 14 inch when i should have had a 12 inch but im going to go ahead and drill the block out to fit a heavier duty stagger bolt 350 starter hopefully itll go smoothly thanks for your help
I put a starter off of a 350 and used the drill guide from Leo Santucci's book and it turned right over =D
| Chevy starter problems | downonthebayou67 | Engine | 10 | 03-29-2010 12:55 PM |
| Another Chevy Starter Issue (pic) | Bluecollarron | Engine | 9 | 12-30-2008 06:09 PM |
| SBC starter problems | punk1c5040 | Engine | 26 | 12-28-2008 07:58 AM |
| Starter shifting and grinding.. new starter? Where does starter brace go? | 84Z | Engine | 8 | 11-12-2007 02:44 PM |
| PLEASE help, starter problems | ktusc | Engine | 6 | 09-07-2003 07:55 AM |
