starter to flexplate gear spec - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2013, 08:41 PM
Banned
Hello.. while going down my check list. I got to thinking(dangerous)
that while the engines out. I'd check the clearance of the starter drive and ring gear.. is their a clearance spec.. or is it just go/no go
it's a sbc and I'd rather get it fitted with shims if needed before it's all in and headers on and get that lovely screach that grinding metal makes..
figure 10 minutes now. is worth the headache later after it's all buttoned up. and have to drop the starter/headers/etc to add a shim..
thanks...
Old 05-16-2013, 09:06 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I've always used the paper clip method, with the gear engaged a standard paper clip, straightened out, should slip between the high point and tooth valley, however many thousandths that is.
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
gearheadslife (05-16-2013)
Flexplate hitting against starter gear? LEROYDOZOIS Engine 2 07-19-2012 10:59 PM
Starter gear/flexplate mismatch? rdsieveke@gmail.com Engine 2 07-27-2011 09:44 PM
Powermaster starter gear walks into flexplate after engine starts zildjian4life218 Engine 4 05-31-2011 09:51 AM
Starter gear to flexplate clearance 87SS Engine 7 07-22-2008 07:03 PM
Starter gear to flexplate gap on SBC 32vicky General Rodding Tech 2 05-14-2003 06:39 PM
