starter-flywheel engaging - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2005, 11:07 AM
Hey guys, I'm trying to install a starter into my girlfriends 95 saturn SL (i know it isn't a hotrod). Its a rebuilt starter...i've installed it and the starter runs but doesn't engage the flywheel. How can I be sure that the flywheel is engaged when I install it? I can't see the flywheel so is there a sound, etc. Thanks, Adam
Old 08-21-2005, 06:34 PM
docvette's Avatar
Wiki Edits: 12
Saturn
Doc here
What 'I know BOUT Saturn's..you cold put in a thimble..
However, If the mechanics are similar to a General Mystery, (GM) you may require shims to adjust up / Down , In / Out spacings..Also the diameter and tooth count may vary with different years..
All questions to ask your parts guy..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-21-2005, 11:25 PM
double check
adrock,
double check with parts guy to make sure your starter is correct. If you turn the key, and here the whirring sound of a starter and the engine doesn't turn over, then you have to small of a gear. Wrong model of starter, and find a new parts guy. If the starter is making a clicking noise or a knock, it is probably engaging. Unfortunately, that may a clue to larger problems. Find out what size of socket will fit on the end of the cranksaft bolt, and make sure the motor will turn over manually. If the motor will turn by hand, the starter may be faulty, or there may be a wiring problem. Let us know!
good luck,
Scott
SBC Starter and flywheel problems WakBordr7387 Engine 18 03-05-2011 02:13 AM
flywheel starter problem kenwood10 General Rodding Tech 1 07-22-2005 06:45 PM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
Starter not engaging flywheel dpjmw Engine 1 12-19-2003 09:21 PM
STARTER AND FLYWHEEL DOESN'T MATCH UP mrmonte2323 Engine 8 11-19-2002 06:37 PM
