starter / flywheel help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2009, 12:51 PM
Need some information.Here is what i have.
327 with a small gm flywheel,i am using a 55-57 gm bell housing (straight drive) Does anyone know if they make a starter that will fit the bell housing that will go with the small flywheel. I have a starter now it bolts up fine but it is for a big flywheel. Before i take everything out and change it.I would like to know what is out there, that might work, or maybe make changes to mine that i have now.Thanks
Donnie
Old 07-12-2009, 01:22 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
if my memory serves... the starters that bolt to a bell housing with 3 bolts... there is only one design / set back spacing
Not like the starters that bolt to the engine block of chevys where there are two spacing designs
SBC Starter and flywheel problems WakBordr7387 Engine 18 03-05-2011 02:13 AM
350 Chevy starter pinion to flywheel clearance Bonehead4x4 Electrical 8 03-28-2009 03:49 PM
starter flywheel issues chevyboy907 Engine 14 11-21-2008 06:25 PM
Chevelle 396 Starter & Flywheel SS396 Engine 3 08-15-2007 09:24 AM
STARTER AND FLYWHEEL DOESN'T MATCH UP mrmonte2323 Engine 8 11-19-2002 06:37 PM
