Starter Grind after adjusting Valve Lash - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2009, 10:05 AM
Ok guys got a wierd one. Not sure if the two are related or not. It's on a 78 350.
The other day I was attempting to adjust my valve lash with the truck running. Cause of the clicking/tapping sound from what seemed to be loose rockers. Adjusted drivers side rockers and motor died. Loosened the rockers up a bit and went to start it back up. Cranked over a couple times but wouldn't start. Loosened the rockers a bit more. Went back to start it and it just made the dreaded starter grind noise. Checked the flywheel teeth and they all look fine. Looks like the starter isn't engaging the flywheel or at least the flyhweel doesn't spin when cranking. My question is... Would adjusting the lash incorrectly cause this. I haven't had any starting issues with it up until now. It's just coincidental it happenned while I was adjusting valve lash.
Old 06-04-2009, 11:43 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Start over with the valves.
Get it to TDC #1 (air coming out of #1 plug hole)
Adjust these valves: Ex, 1,3,4,8 - In, 1,2,5,7
Roll engine ONE rev back around clockwise to TDC again.
Adjust these valves: Ex, 2,5,6,7 - In, 3,4,6,8
To adjust back off rocker until loose (wide lash) run it down to NO LASH then go 1/2 turn. This preloads the lifter plunger .030 =/- a few where it should be.
That's it.
Old 06-04-2009, 12:04 PM
Thanks. I'll do it now. So you think this is what's causing the problem?
Old 06-04-2009, 12:39 PM
It's fixed!! Thanks C-10
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
Valve Lash???? Help haley72 Engine 19 03-10-2007 12:13 PM
How In The World Do You Adjust The Valve Lash ? SCHOONER Engine 8 10-06-2006 04:18 PM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
Valve lash changing, sbc! al37ford Engine 12 09-21-2004 10:16 AM
