Starter GRINDING!?!?!?! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2010, 10:01 PM
so i have a 78 chevy cheyenne thtruck runs great and drives great but the starter is makin me rip my hair out. I have tried shimming it, shaving it, replaced wires. i Put a new starter in and it is fixed for the first 3 times i start it than grinds. If i crawl under it when its grinding and loosen than tighten the starter bolts it will fire right up with out a noise but it progresses. i have gone through 6 starters that it has physically broken to where i climb under it and the casings loose and the housings cracked. most recently the starter bolt randomly broke and fell out in the driveway???? please help as it is the only thing wrong with my beautiful truck sorry its so long thanks for a reply
Old 08-18-2010, 10:57 PM
MyRed78,
Do you have the front bracket? This is bolted from the top starter through bolt to the side of the block.
Scholman(retired)
Old 08-20-2010, 07:34 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
when did this problem start? after you put on a new starter ? change the engine and use different flex plate? Wich flex plate do you have? What is the starter bolt pattern ? is it straight across,? staggered ? 153 tooth flex or 168 tooth?
Old 08-20-2010, 08:07 PM
poncho62's Avatar
Wiki Edits: 5
Are you using the correct knurled bolts??? Also stressing the front bracket be used.
Old 08-20-2010, 08:29 PM
life is a temporary assignment
That has been a ''Big'' Problem with Chevy starters lately...
SBC Starter grinding on flexplate tylerwerrin Engine 1 03-29-2010 07:10 PM
starter grinding update Powermaster starter question RossR90 Engine 2 08-11-2008 02:46 PM
Starter grinding.. need help RossR90 Engine 26 07-11-2008 01:46 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
Starter not engaging properly... Horrible grinding 84Z Engine 5 09-01-2007 07:30 PM
