Starter help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2012, 07:05 PM
Starter help
starter solenoid wire was too close to header and it sparked when hit the key...now it cranks a little then grinds and starter gear locks in too flywheel did i smoke the starter or the solenoid?
Old 10-04-2012, 03:50 AM
EOD Guy's Avatar
That would be my guess, you might have smoked the windings in the starter.
Old 10-05-2012, 02:05 PM
Neither one. The spark was a short to ground before it got to the solenoid/starter. What that does is possibly damage the battery or the cable connection if it sparked for any length of time. It's not uncommon for the starter drive to stick in the ring gear when the battery is low and the engine won't start. The release of pressure when the engine first starts is part of what helps the drive retract.....along with that spring in the solenoid.
Starter help. Can you make a new starter old? Hogger Engine 2 09-21-2010 10:48 PM
changed from oem starter to high tork mini starter , wires .? don wills Electrical 2 09-04-2010 05:34 PM
starter grinding update Powermaster starter question RossR90 Engine 2 08-11-2008 02:46 PM
My new Starter Nite Life Engine 1 01-04-2008 02:32 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
