Starter help. Can you make a new starter old? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2010, 07:18 PM
I have a bit of a dilemma and figure you guys would be the best to help me.
I have a 4.3L Mercruiser engine(chevy 262) in my boat and I have a badly cracked starter mount hole. I have read too many horror stories about welding and JB welding it. And mine is cracked on two sides top to bottom. Not really sure what's holding it on.
So I've decided to try the plate that goes around the bellhousing I saw on Danchuk
Now my dilemma.
I need a starter that can mount to that plate and is safe to use in a boat.
I have the offset two bolt marine starter. Does anyone know if you can swap the front of a new starter to one of a 1955 or '56 so it will mount on the plate?
Or is there some conversion kit so guys can use new starters on old cars?
Thanks. Jordan.
Old 09-21-2010, 09:28 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
This might help you.
http://www.stevesnovasite.com/forums....php?p=1243784
Old 09-21-2010, 10:48 PM
Last journal entry: Unpacking
Now my dilemma.
Thanks. Jordan.
yes, the nose cones can be swapped. some blocks also have 3 bolts for the starters that mount with the bolts straight or offset.
How to make remote starter 350pano Electrical 8 05-12-2009 05:22 PM
will starter make noise when egines running?? dannyessexc Electrical 6 04-07-2009 07:17 AM
84' 350 SBC Starter Problems Gokussj5okazu Engine 8 05-14-2007 05:16 PM
Starter Solution dollybud Electrical 0 09-30-2003 06:42 AM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 05:48 PM
