starter issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2007, 02:37 PM
starter issues
i got a blazer and the starter messed up. i put a new starter on and there is no power so i put a jumper cable to the pos. post on the starter and i got power but it would not turn over fast enough??????
Old 01-10-2007, 03:06 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Have you got a good ground? Is the battery fully charged? Give us some more info.
Old 01-10-2007, 03:53 PM
starter
the starter was starting to just whine and then grab every once and awhile. it was grounded good before but then i shut the truck off and went to start it back and there was no power.and the battery is brand new. when i put the pos. cable to the starter it had power but not enough to turn over it just clicked??please help me!!!thank you
Old 01-10-2007, 05:30 PM
Gokussj5okazu's Avatar
Last journal entry: 336 Stroker: Teardown
Could be a number of things. Make sure your ground wire is tight to start. If your wiring's all sound inspect the solenoid.
Old 01-10-2007, 11:52 PM
DR132's Avatar
Sophisticated Minimalist
just so you know, just because a battery is "brand new" does not necessarily mean that it is a good battery...not saying that's problem, just letting you in on that little piece of info...if you have a volt meter then that can help you track down your problem as long as it's in the electrical system...if it's not, then I suggest you take your starter to an auto-electric shop if you have one nearby or some shop where they can test and rebuild your starter if necessary...could need a new solenoid or a new drive...thats my recommendation...good luck
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 02:41 PM
starter issues twisted91 Electrical 4 08-07-2006 01:06 AM
Some Starter Issues MrBBonz Engine 3 05-04-2005 09:44 AM
starting issues...battery or starter? 79454 Engine 6 10-25-2003 04:10 PM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 05:48 PM
