starter issues - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-13-2011, 09:10 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Sometimes you only need to put shims on one bolt, they are thin and can be cut, that will rotate the starter, You only need a paper clip thickness for clearance of the ring and starter gear..
Just to refresh, you put a 4 speed on, bell housing was change of course, but the question I have is why did you not reuse the original starter, it was working correct? Just for grins count the teeth on the starter gear, not the fly wheel. The new one and the old ones, all three, how many did you find?
One was from an auto trans and one from the manual. I do not think there is a difference in the tooth count, on the starter gear. I have never had to check that .
I do not think there is a different starter for auto and manual, he has the starter from the donor that he's got the 4 speed from. So if there is a difference it should be right in front of him to see.
  #17 (permalink)
Old 08-13-2011, 09:17 PM
I tried my original starter first but none of them really worked. Have you ever heard of anyone having this much trouble with a auto to manual conversion?
  #18 (permalink)
Old 08-13-2011, 09:20 PM
pepi's Avatar
So neither would engage the fly wheel ?
  #19 (permalink)
Old 08-13-2011, 09:22 PM
pepi's Avatar
Both motors the same year?
  #20 (permalink)
Old 08-13-2011, 09:25 PM
Thanks, what do mean by bearing retainer?
  #21 (permalink)
Old 08-13-2011, 09:27 PM
No neither would fully engage and turn over the motor. NO both motors are not the same year. and both truck have crate motors so Im not sure of the year all i no is my truck has a two piece rear main and the donor truck has a one piece.
  #22 (permalink)
Old 08-13-2011, 09:38 PM
pepi's Avatar
Ok so the pinion gear was fully extending and not reaching the ring gear on the flywheel. That makes me think the flywheel is wrong for the motor in your truck. Not what you want to here, I am going to look up a part number be right back.
  #23 (permalink)
Old 08-13-2011, 09:40 PM
Also the bellhousing for the tranni is a truck housing and was on the donor truck and running up until I took it out. It bolted right up to my truck wihout a problem.
  #24 (permalink)
Old 08-13-2011, 09:43 PM
NO it was reaching the ring gear but was and still is chattering and barely turning the engine over. Not even turning enough to start. and then when I stop trying to start the truck and go underneath to check its stuck in the flywheel and dosen't retract.
  #25 (permalink)
Old 08-13-2011, 09:49 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Bearing retainer---
When you mention Muncie 4 spd----I think of a car trans.
But in your defense---I have a Muncie in my 79 C-10----not a car trans.
It's that big ol' heavy truck granny trans.
Bearing retainer on the truck trans is larger than on a car trans.
That is the piece that bolts onto the front of the trans and looks kind of like a teepee---that the input shaft goes thru and the throwout bearing slides on.
As for flywheels-----not sure but I thought the one piece seal motors and the 2 piece seal motors used different flywheels .
They certainly do on the big block motors.
Starters are different----I have 2 73 Malibus----one AT and one a 3 spd manual----different starters
I would double check everything. When I went from an AT to a manual in my 79, waaaay back in 86, I don't recall running into any issues other than the trans crossmember (different on AT vs Manual) and installing a center bearing crossmember for my driveshaft. That was kind of a pain as that crossmember also supports the back of the cab. AND---my AT starter would not work.
Another option would be an aftermarket hi torque mini starter.
I have one in my 59 (454 and a 5 spd) and tht thing spins the motor just great----heat does not affect it, and it is easy to disconnect wiring and remove. The same cannot be said for a stock GM starter.
  #26 (permalink)
Old 08-13-2011, 09:53 PM
pepi's Avatar
http://www.summitracing.com/compare.aspx
take a close look at these two, one is for internal and the other is for an external balanced motor, are both motors balanced the same? The fly wheels look like one is thicker then the other, that could effect the way the fly wheel hangs off the back of the crank, and that would effect the ring gear placement to the starter.
You should take the number off the two blocks and see what you have, that number will be passenger side front where the head meets the block. This is sounding more and more like a mismatch of parts..
  #27 (permalink)
Old 08-13-2011, 09:54 PM
Ok thanks. Yeah the flywheels are different which I mentioned earlier in my postings. I got the correct flywheel from a chevy van same era as my truck with a two peice seal. My crankshaft is externally balanced. The donor truck was newer and internally balanced and the crankshaft hole diameters are different.
  #28 (permalink)
Old 08-13-2011, 10:00 PM
Thank bryan and pepi. I really appreciate the help. Everyone seems to be confirming that everyhing SHOULD work. I'll have to do some more research and make sure I'm getting the right starter.
  #29 (permalink)
Old 08-13-2011, 10:02 PM
What confuses me is I didn't think the wrong flywheel could bolt up to the wrong engine???
  #30 (permalink)
Old 08-13-2011, 10:06 PM
pepi's Avatar
This is the original starter you are talking about here and you can not shim it out far enough to correct the problem, then my guess is that you will need 153 tooth flywheel.
http://www.summitracing.com/parts/SUM-700186/
Sounds to me it is not hitting home and just hanging and jammed, how much of the starter pinion is actually engage .. 1/4 1/2
Got to go need to get up a 530, I will check back tomorrow, we have certainly found some things to look into . My money in on the flywheel.
starter issues mkjarobinson Engine 2 06-16-2008 09:40 AM
Starter issues........ muzzfactor Engine 20 06-19-2007 06:05 PM
starter issues ajh86 Engine 4 01-10-2007 11:52 PM
starter issues twisted91 Electrical 4 08-07-2006 01:06 AM
Some Starter Issues MrBBonz Engine 3 05-04-2005 09:44 AM
