Could be mechanical, like a starter that isnt shimmed right(too tight) or an electrical issue like a weak ground to the ford solenoid,causing it to act like a shunt,when current draw is high (like when cranking) it stays in, after engine starts, current draw goes down (less power required-engine running) , when current draw drops, solenoid releases. A bad ground can exaggerate the "shunt" condition. I have had a poorly grounded ford solenoid cause a starter to stay engaged a few times in my career.
Also the ford solenoid could be mechanically sticking internally as well as the GM solenoid on the starter could be hanging in. Could be rusty or in need of a stiffer return spring. Just a few thoughts. How is the ford solenoid wired in? Purple wire from key to ford solenoid-large terminal to S terminal???
Fact is stranger than Fiction |
hang up
At the starter disconnect the purple wire at the S terminal. Then run a jumper from the battery + to the S terminal or a remote start button. If the car starts normally, the starter is OK. If not the starter is hanging up.
Next get rid of the Ford solenoid. This site has some folks who like to use them but I am not convinced they help anything. vicrod |
| Starter help. Can you make a new starter old? | Hogger | Engine | 2 | 09-21-2010 10:48 PM |
| changed from oem starter to high tork mini starter , wires .? | don wills | Electrical | 2 | 09-04-2010 05:34 PM |
| starter grinding update Powermaster starter question | RossR90 | Engine | 2 | 08-11-2008 02:46 PM |
| Starter shifting and grinding.. new starter? Where does starter brace go? | 84Z | Engine | 8 | 11-12-2007 02:44 PM |
| Which starter to get. | oregon chevelle | General Rodding Tech | 1 | 02-23-2007 04:48 PM |
