Starter keeps turning - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2010, 03:00 PM
350 chevy, just put a new starter on and now the starter keeps cranking after the key is turned back to run. Solenoid sticking? I wired it just like the old starter, I just don't know.
Old 10-10-2010, 06:12 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Could be a bad solenoid or a wire re-check the wires. Also what year is the vehicle could have a bad relay.JMO
Cole
Old 10-10-2010, 09:44 PM
DENCOUCH's Avatar
inspect to see if the solenoid control wire is not bearing against the power cable from the battery.
The battery cable had a large bare lug that if the control wire is lying against it, can power the solenoid if the two are shorting out.
Old 10-11-2010, 10:14 AM
eloc431962's Avatar
Wiki Edits: 37
You know i have seen some new parts be bad also. JMO
Cole
Old 10-11-2010, 11:13 AM
DoubleVision's Avatar
Years ago I had a 79 Z28 that did this same thing, I checked the solenoid and it was melted internally.
Old 10-11-2010, 12:10 PM
Dirty Biker's Avatar
Bold As Love
Did it come with shims? Sounds like it could be too tight against the ring gear, adding a shim or two can get it a little farther away. I have only had to use them once, and it was to fix a starter run on problem, where you could rev the motor a little and it would stop sticking. The shim fixed it. The last starter I put on a month a ago came with a few in the box but I didn't end up needing em
Old 10-11-2010, 01:42 PM
eloc431962's Avatar
Wiki Edits: 37
X2 on the shims, I was thinking about them and seen where you posted good call, Could very well be the problem. Don't hapen very often but does happen just the same.
Cole
Old 10-11-2010, 08:57 PM
Sorry guys, I double posted and lost track. The solenoid was bad so I bought a rebuilt starter and it works. The new starter(made in china) was shimed correctly and sounded fine, it's just that you had to remove the battery cable to stop it. I could have taken it apart and fixed it but it really bugs me to repair a "new" part. Thanks for the responses.
Need Help: Chevy starter housing ChevyBass Engine 9 03-30-2008 07:51 PM
350 starter buzz VEGA 3503508.5 Engine 10 04-03-2006 09:36 PM
Starter keeps starting and battery exploded Huug Electrical 13 10-06-2005 05:48 PM
Starter woes Again dollybud Electrical 11 09-01-2004 04:16 PM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 05:48 PM
