Starter Lube - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2004, 03:39 PM
Phillfam99's Avatar
Starter Lube
Hey, Ranger Here again with an easy question. I am re building a 46 chevrolet fleetmaster starter. What kind of lubrication, if any should I use when using the rebuild kit from Chev's of the 40's?
Thanks for your wisdom!
Old 12-06-2004, 09:38 PM
willys36@aol.com's Avatar
Wiki Edits: 21
I'm not familiar with that particular starter but a light coating of regular high pressure grease on the Bendix and engine oil in bushings is all that is needed.
